StarTech.com 1 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45...
StarTech.com 1 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
£7.33
22 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make 10Gb Ethernet connections with PoE support. This high quality (gray) 1ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
Product Description StarTech.com 1 ft CAT6a Ethernet Cable - 10 Gigabit Category 6a Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE Gray UL/TIA Certified - patch cable - 30 cm - grey
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Wiring Scheme T568B
Shielding Material Aluminium-polyester foil
Wires per Cable 8 wires
Features Molded
Length 30 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Cat...
£7.33
