StarTech.com 1 ft Cat5e Gray Snagless RJ45 UTP Cat 5e Patch C...
StarTech.com 1 ft Cat5e Gray Snagless RJ45 UTP Cat 5e Patch Cable
£3.25
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 30cm
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PATCH1GR Cat5e Patch Cable (1 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description StarTech.com Cat5e Ethernet Cable - 1 ft - Gray- Patch Cable - Snagless Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 1ft (45PATCH1GR) - patch cable - 30 cm - grey
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wires per Cable 8 wires
Features Snagless
Length 30 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Cat5...
£3.25
