StarTech.com 1 ft Coax HD15 VGA to 5 BNC RGBHV Monitor Cable...
StarTech.com 1 ft Coax HD15 VGA to 5 BNC RGBHV Monitor Cable - M/F
£7.89
21 in stock
Delivery:
Standard: 1-3 working days
  • Type: VGA
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Connect a BNC video source to a VGA distribution amplifier or PC. The VGABNCMF1 1-foot Coax HD15 VGA to 5 BNC RGBHV Adapter Cable features an HD15 VGA (male) connector and 5 BNC (RGBHV) (female) connectors, allowing you to connect your existing BNC video source to a VGA distribution amplifier or PC.
The cable can also be used with a VGA out signal, breaking out to 5 BNC female connectors that can be used with a 5 BNC (M-M) cable for use with a BNC monitor/display.
Product Description StarTech.com 1 ft. (0.3 m) VGA to BNC Cable - HD15 VGA to 5 BNC - Male/Female - BNC Cable (VGABNCMF1) - VGA cable - 30 cm
Type VGA cable
Technology Coaxial
Length 30 cm
Connector 5 x BNC - female
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Coax...
£7.89
