StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B
£2.24
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Provides unrestricted access to your Micro-B USB devices, in landscape or portrait mode, even while charging
  • Guaranteed reliability
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB1LA 1-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smartphones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB1RA 1ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
Product Description StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B - USB cable - 30 cm
Type USB cable
Features 90° connector, left-angled connector
Length 30 cm
Connector 4 pin USB Type A - male
Connector (Second End) 5 pin Micro-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Micr...
£2.24
