StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboar...
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F
£5.05
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Stock Status: In Stock
Product codes
This 1ft USB to Panel mount USB cable features a 5-pin motherboard header connection on one end and a panel mount USB A (female) port on the other, providing a simple and easy to access USB 2.0 port on a panel mount receptacle.
The USB panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB connection.
Product Description StarTech.com 1 ft Panel Mount USB A to Motherboard Header Cable F/F - USB internal to external cable - 30 cm
Type USB internal to external cable
Features Thumbscrews
Length 30 cm
Connector 4 pin USB Type A - female
Connector (Second End) 5 pin USB 2.0 header - female
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Pane...
£5.05
