StarTech.com 1 ft Panel Mount USB Cable A to A - F/M
£5.08
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Customize your solutions – mount a USB-A port on your PC, or faceplate on your podium or kiosk through an available USB female connector
  • Configure your systems as needed, extend your USB motherboard connection by 1ft
  • Guaranteed reliability
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM1 1ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 1ft, enabling you to place the cable as needed within the system case.
Product Description StarTech.com 1 ft Panel Mount USB Cable A to A - F/M - USB extension cable - 30 cm
Type USB extension cable
Features Molded, thumbscrews
Length 30 cm
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type A - female
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: UUSBOTG
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Pane...
£5.08
