StarTech.com 1 ft Panel Mount USB Cable B to B - F/M
£5.13
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Stock Status: In Stock
Product codes
For customized USB device solutions; allows the USB connection to be mounted on a secure easily accessible panel. The USBPNLBFBM1 USB B to USB Panel mount cable features a USB type B male connector on one end, and a USB panel mount B (female) molded connector on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
Product Description StarTech.com 1 ft Panel Mount USB Cable B to B - F/M - USB cable - USB Type B (F) to USB Type B (M) - USB 2.0 - 1 ft - molded, thumbscrews - black - USBPNLBFBM1 - USB cable - 30 cm
Type USB cable
Features Molded, thumbscrews
Length 30 cm
Connector 4 pin USB Type B - female
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Pane...
£5.13
