StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/...
StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
£12.37
Delivery:
Product codes
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices, with reduced clutter. The DISPLPORT1L 1ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The short 1-foot DisplayPort cable is perfect for mobile applications, such as connecting your laptop to a monitor and it provides a portable solution that makes it perfect for carrying as a laptop accessory.
Product Description StarTech.com DisplayPort Cable - 1 ft - with Latches - Short DP Cable - 4K DisplayPort to DisplayPort Cable - DisplayPort 1.2 Cable (DISPLPORT1L) - DisplayPort cable - 30 cm
Type DisplayPort cable
Technology Shielded
Features Latched, molded
Length 30 cm
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2DP, CDP2DP14B, CDP2DPUCP, CDP2DPW, DVI2DP2, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPDVHD, MDP2DPMF6IN, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV211DPUA, SV211DPUA4K, SV231DPDDUA2, SV431DPDDUA2, SV431DPUA2, TB32DP2, USB32DP24K60, USB32DP4K, USB32DPPRO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Shor...
£12.37
