Connect and power your external mini-USB equipped hard drive through two standard USB ports on your computer. The USB2HABMY1 1 ft USB-A to Mini-B Y cable features two USB-A male connectors and a single USB Mini-B male connector - an ideal solution for providing additional power to your mini-USB external hard drive by connecting to two USB-A ports on your computer or laptop.
Especially valuable in situations where a single USB 2.0 port may not offer sufficient power to external hard drives, the USB2HABMY1 can be connected to two ports on one PC to increase the power output to power the external device.
Product Description | StarTech.com 1 ft USB Y Cable for External Hard Drive - USB A to mini B - USB cable - 30 cm | Type | USB cable | Length | 30 cm | Connector | 2 x 4 pin USB Type A - male | Connector (Second End) | Mini-USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 24/28 |
Length | 30 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
