Mirror the output from a VGA source to two VGA monitors. This VGASPL1VV 1-foot VGA video splitter cable lets you connect two VGA displays to a single VGA video source.
Product Description | StarTech.com 1 ft. VGA to VGA Splitter Cable - M/F Dual Monitor Video Cable Splitter (VGASPL1VV) - VGA splitter - 30 cm | Type | VGA splitter | Length | 30 cm | Connector | HD-15 (VGA) - male | Connector (Second End) | 2 x HD-15 (VGA) - female | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM |
General | |
American Wire Gauge (AWG) | 28 |
Plated Connector | Gold |
Length | 30 cm |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 2 x 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
