StarTech.com 1 Port 10G NIC w/ Chassis
£495.87
Delivery:
Standard: 1-3 working days
  • Wired / Wireless: Wired
  • Protocol: 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet, Fast Ethernet + 1 more
  • Type: Network adapter
  • Stock Status: In Stock
Product codes
This Thunderbolt 3 to 10GbE adapter lets you connect your Thunderbolt 3 enabled device to a 10 GbE network via an expansion chassis. This Thunderbolt 3 to 10GbE NIC lets you connect your Thunderbolt 3 enabled device to a 10 GbE network. This adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the PCI Express 10G NIC (ST10000SPEXI), giving you one DisplayPort output, one additional Thunderbolt 3 port and one RJ45 (10GbE) port.
This 10G network card utilizes the Intel X550 chipset with Intel Virtualization Technology for connectivity, delivering the power, performance and enhanced capabilities you need for dependable network connections.
Requiring only a Phillips type screwdriver, this Thunderbolt 3 to 10GbE NIC can be assembled and connected in minutes. It connects easily through a single Thunderbolt 3 port on your computer.
The Thunderbolt 3 chassis not only pairs well with the 10GbE NIC - you can swap the NIC out for other PCIe cards, to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to effortlessly multitask.
Product Description StarTech.com Thunderbolt 3 to 10GbE NIC Chassis + Card - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Bundled with Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type PCI Express 3.0 x4
PCI Specification Revision PCI 3.0
Ports 1/2.5/5/10GBase-T x 1
Cabling Type Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
Data Link Protocol 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
Data Transfer Rate 10 Gbps
Capacity Jumbo frame size: 9000
Processor Intel X550-AT
Compliant Standards IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3q
System Requirements Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Apple macOS 10.12 - 10.13
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port 10...
£495.87
