This Thunderbolt 3 to 10GbE adapter lets you connect your Thunderbolt 3 enabled device to a 10 GbE network via an expansion chassis. This Thunderbolt 3 to 10GbE NIC lets you connect your Thunderbolt 3 enabled device to a 10 GbE network. This adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the PCI Express 10G NIC (ST10000SPEXI), giving you one DisplayPort output, one additional Thunderbolt 3 port and one RJ45 (10GbE) port.
This 10G network card utilizes the Intel X550 chipset with Intel Virtualization Technology for connectivity, delivering the power, performance and enhanced capabilities you need for dependable network connections.
Requiring only a Phillips type screwdriver, this Thunderbolt 3 to 10GbE NIC can be assembled and connected in minutes. It connects easily through a single Thunderbolt 3 port on your computer.
The Thunderbolt 3 chassis not only pairs well with the 10GbE NIC - you can swap the NIC out for other PCIe cards, to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to effortlessly multitask.
Product Description | StarTech.com Thunderbolt 3 to 10GbE NIC Chassis + Card - network adapter | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Bundled with | Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort | Interface (Bus) Type | PCI Express 3.0 x4 | PCI Specification Revision | PCI 3.0 | Ports | 1/2.5/5/10GBase-T x 1 | Cabling Type | Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T | Data Link Protocol | 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE | Data Transfer Rate | 10 Gbps | Capacity | Jumbo frame size: 9000 | Processor | X550-AT - Intel | Compliant Standards | IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3q | System Requirements | Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Apple MacOS X 10.12 - 10.13 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet |
Features | Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 1 fan, VLAN Tagging |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x 1/2.5/5/10GBase-T - RJ-45 - female |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Cables Included | 1 x Thunderbolt 3 / USB-C cable (external) - 50 cm |
Compliant Standards | FCC, RoHS, WEEE |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Apple MacOS X 10.12 - 10.13 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
