The Power over Ethernet PCIe network card enables multigigabit speeds of 2.5/1Gbps and 100/10Mbps. This PoE LAN adapter can provide up to 25.5 W of power to a connected device. It combines a network data connection and power over a single Cat5e (or better) Ethernet cable. This PoE NIC is the ideal solution to provide both power and network communication to a remote installation.
Product Description | StarTech.com 1 Port 2.5Gbps PoE Network Card, PCIe Ethernet Card w/RJ45 Port, 30W 802.3at PoE NIC for Desktops/Servers, Network PoE LAN Adapter w/Low-Profile Bracket Included - NBASE-T, Windows/Linux Support (ST1000PEXPSE) - network adapter - PCIe 2.1 - 2.5GBase-T (PoE+) x 1 | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express 2.1 x1 | Ports | 2.5GBase-T (PoE+) x 1 | Dimensions (WxDxH) | 1.5 cm x 9.5 cm x 6.3 cm | Weight | 220 g | Cabling Type | Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, NBase-T | Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE, 2.5 GigE | Data Transfer Rate | 2.5 Gbps | Capacity | Jumbo frame size: 16000 | Processor | 1 x Realtek Semiconductor RTL8125B | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bz, IEEE P802.3az | System Requirements | Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8.1 / 10, Microsoft Windows Server 2019, Microsoft Windows 11, Linux Kernel 2.4.20 or later (LTS versions only) | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet |
Status Indicators | PoE, link |
Features | Flow control, full duplex capability, power over Ethernet (PoE), wake on LAN (WOL), Power Sourcing Equipment (PSE), Energy-Efficient Ethernet (EEE), VLAN Tagging, RealWoW! Technology, 30W PoE+ power budget, Automatic Media-Dependent Interface Crossover (MDIX), PXE boot |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x 1/2.5GBase-T (PoE+) - RJ-45 , 1 x SATA power - 15 pin Serial ATA power , 1 x SP4 power - 4 pin connector - male |
Miscellaneous | |
Included Accessories | Low-profile bracket, full-height bracket |
Compliant Standards | RoHS, WEEE, RCM |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8.1 / 10, Microsoft Windows Server 2019, Microsoft Windows 11, Linux Kernel 2.4.20 or later (LTS versions only) |
Dimensions & Weight | |
Width | 1.5 cm |
Depth | 9.5 cm |
Height | 6.3 cm |
Weight | 220 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years , Technical support - assistance - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 5 - 95% RH |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
