StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller C...
StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card w/ LP Bracket
£15.03
Delivery:
Standard: 1-3 working days
Key features
  • Dual profile support with low profile and standard size PCI brackets included
  • Provides a 32bit, 33/66 MHz PCI interface on the host side and dual, fully compliant Serial ATA ports on the device side
Product codes
Add an internal SATA port and an external SATA (eSATA) port to your desktop computer through a PCI expansion slot. This PCI based SATA Controller Card allows you to turn a PCI slot into one internal SATA and one external SATA (eSATA) connection. Supporting SATA 150 hard drives, and data transfer rates of up to 1.5Gbps, this controller card is the perfect solution if you need an extra SATA port or want to externalize your storage.
Product Description StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card - storage controller - SATA 1.5Gb/s / eSATA - PCI
Device Type Storage controller - plug-in card - low profile
Bus Type PCI
Interface SATA 1.5Gb/s / eSATA
Data Transfer Rate 1.5 Gbit/s
Supported Devices Hard drive
Channel Qty 2
Max Storage Devices Qty 2
System Requirements Microsoft Windows 98 Second Edition, Microsoft Windows Vista / 2000 / XP
Dimensions (WxDxH) 12.1 cm x 5.4 cm x 2 cm
Weight 47 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port eS...
£15.03
