StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card...
StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card -  SPP/EPP/ECP
£56.80
11 in stock
Delivery:
Standard: 1-3 working days
  • Type: Parallel adapter
  • Compatibility: PC
  • Interface: ExpressCard/34
  • Stock Status: In Stock
Product codes
This ExpressCard Parallel Adapter turns an ExpressCard slot into a Parallel port, allowing you to connect parallel devices to a laptop computer. The card is PCI Express (x1) based, ensuring faster data transfer rates between host and peripheral than USB-based ExpressCards - providing a cost-effective way to bridge the compatibility gap between your laptop and legacy devices.
A convenient solution for adding a parallel printer or scanner, simply insert the adapter (EC1PECPS) into an available 34mm or 54mm ExpressCard slot and connect the parallel device to the adapter SPP/EPP/ECP parallel port. The adapter card is WHQL certified, so software installation is automated.
Product Description StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card - SPP/EPP/ECP - parallel adapter
Device Type Parallel adapter
Form Factor Plug-in module
Interface (Bus) Type ExpressCard/34
Ports IEEE 1284
Dimensions (WxDxH) 4.4 cm x 11.5 cm x 2 cm
Weight 40 g
Data Link Protocol Parallel
Data Transfer Rate 1.5 Mbps
System Requirements Microsoft DOS, Linux, Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Ex...
£56.80
