StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable wi...
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation
£86.18
Delivery:
Standard: 1-3 working days
Key features
  • Circuit isolation provides electrical protection for sensitive, and often expensive industrial equipment
  • Portable USB-Powered design requires no bulky power adapter or outlet
  • The FTDI chipset driver is highly customizable and broadly compatible, making it the ideal solution for any setup
Product codes
Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation - serial adapter
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
4.2 cm x 4.5 cm x 2.2 cm
150 g
RS-232
Data Transfer Rate
921.6 Kbps
FT232RL - FTDI
Linux, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port FT...
£86.18
