Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
Product Description | StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation - serial adapter | Device Type | Serial adapter | Form Factor | External | Interface (Bus) Type | USB | Ports | RS-232 | Dimensions (WxDxH) | 4.2 cm x 4.5 cm x 2.2 cm | Weight | 150 g | Data Link Protocol | RS-232 | Data Transfer Rate | 921.6 Kbps | Processor | FT232RL - FTDI | Colour | Black | System Requirements | Linux, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Ports | RS-232 |
Connectivity Technology | Wired |
Features | 2500V isolation, USB powered, plastic housing |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x RS-232 - 9 pin D-Sub (DB-9) |
Connections | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Cables Included | 1 x USB cable (integrated) - 1.8 cm |
Compliant Standards | WHQL, FCC, RoHS |
Colour | Black |
Software / System Requirements | |
OS Required | Linux, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7 |
Dimensions & Weight | |
Width | 4.2 cm |
Depth | 4.5 cm |
Height | 2.2 cm |
Weight | 150 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 5 - 95% |
