StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable wi...
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation
£86.18
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Circuit isolation provides electrical protection for sensitive, and often expensive industrial equipment
  • Portable USB-Powered design requires no bulky power adapter or outlet
  • The FTDI chipset driver is highly customizable and broadly compatible, making it the ideal solution for any setup
  • Stock Status: In Stock
Product codes
Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
Product Description StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Ports RS-232
Dimensions (WxDxH) 4.2 cm x 4.5 cm x 2.2 cm
Weight 150 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Processor FT232RL - FTDI
Colour Black
System Requirements Linux, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port FT...
£86.18
