StarTech.com 1 Port Industrial USB to RS232 Serial Adapter wi...
StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation & 15KV ESD Protection
£64.51
Delivery:
Product codes
Add a galvanically isolated RS232 serial port with ESD protection through a USB port - DIN Rail Mountable. The ICUSB232IS Industrial USB to Serial Adapter lets you add a galvanically isolated RS232 serial port with ESD protection through a USB port and offers a durable DIN Rail-mountable design.
Ideal for industrial environments, the USB serial adapter features an integrated 5KV galvanic isolation circuit and 15KV ESD protection, to protect costly and often sensitive control equipment against electrical damage. An extended operating temperature range (-30°C to 75°C) also helps to ensure performance in harsh environments.
For fast communication with serial peripherals, the adapter features an integrated FTDI chipset, supporting baud rates up to 921Kbps. The adapter also features COM retention that automatically retains COM Port assignments, even through a reboot.
The ICUSB232IS serial adapter is compatible with Windows, Windows CE, Mac OS and Linux which makes it easy to integrate into mixed environments.
Product Description StarTech.com USB to Serial Adapter - Industrial - 5KV Isolation and 15KV ESD Protection - FTDI - USB to RS232 Adapter Cable (ICUSB232IS) - serial adapter
Device Type Serial adapter
Form Factor DIN rail mountable
Interface (Bus) Type USB
Ports RS-232 x 1
Dimensions (WxDxH) 9.3 cm x 4.2 cm x 2.2 cm
Weight 25 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Colour Black
System Requirements Linux 2.6.x or later, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE .NET 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port In...
£64.51
