StarTech.com 1 Port Low Profile Native PCI Express Serial Car...
StarTech.com 1 Port Low Profile Native PCI Express Serial Card w/ 16950
£44.89
Delivery:
Product codes
Low Profile PCI-Express 16C950 Serial Card. The PEX1S952LP 1 Port Low Profile Native PCI Express RS232 Serial Adapter Card with 16950 UART adds an RS232 (DB9) Serial Port with data rates up to 460 Kbps to a computer through an available low profile PCIe slot, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability and reducing the load applied to the CPU by as much as 48% over conventional (bridge chip) serial cards.
The 1 port RS232 serial card features a half-height PCI Express mounting bracket that's designed specifically for low profile/small form factor computer cases, and includes an optional standard height bracket as well. Compatible with a broad range of operating systems including Windows and Linux for easy integration into mixed environments.
Product Description StarTech.com 1 Port Low Profile Native PCI Express RS232 Serial Card with 16950 UART - PCIe Serial Card - 1 Port LP RS232 Card (PEX1S952LP) - serial adapter
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.0a
Bus Voltage 3.3 V
Ports RS-232
Dimensions (WxDxH) 9 cm x 6.5 cm x 2 cm
Weight 48 g
Data Link Protocol RS-232
Data Transfer Rate 460 Kbps
System Requirements Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Lo...
£44.89
