StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Seria...
StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation
£86.91
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: USB
  • Stock Status: In Stock
Product codes
Add an R422/485 serial port to your laptop or desktop computer through USB.
The ICUSB422IS 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter w/ Isolation connects to a computer using USB and allows you to connect any RS-422 or RS-485 serial device via the provided DB9 port or hard-wired to the terminal block. The USB to serial adapter features circuit isolation to ensure that sensitive controls and devices will not be damaged while connected, making it a viable solution for connecting costly industrial serial devices. The RS422/485 Converter receives full power via the host USB connection, and provides power to the attached serial device without requiring an external power adapter. Designed to provide a durable serial solution, the USB to RS422/485 Converter is ruggedly constructed and can be mounted nearly anywhere.
Product Description StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter w/ Isolation (ICUSB422IS) - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Dimensions (WxDxH) 5.4 cm x 2.3 cm x 9.3 cm
Weight 300 g
Data Link Protocol RS-422, RS-485
Data Transfer Rate 921.6 Kbps
Colour Black
System Requirements Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Me...
£86.91
