StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter C...
StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART
£45.06
10 in stock
Delivery:
Standard: 1-3 working days
Product codes
This 1 Port Serial ExpressCard Adapter lets you add an RS232 serial port to your laptop or ExpressCard-equipped desktop computer.
The serial ExpressCard is designed based on a single-chip architecture (as opposed to cards that use a "bridge chip"), providing native PCI Express communication for greater performance and reliability, and reduced power consumption and CPU load.
An included 34mm to 54mm ExpressCard stabilizer adapter bracket allows the EC2S952 to fit in both 34mm and 54mm ExpressCard slots. This serial adapter features 128-byte FIFO communication and a high performance 16C950 UART.
Providing optimal communication with RS232 serial devices, the serial ExpressCard supports data transfer rates of up to 460Kbps, saving time and hassle.
StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16952 UART - serial adapter
Serial adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
RS-232
4.5 cm x 11.5 cm x 2 cm
34 g
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95/98/ME/XP, Microsoft Windows Vista
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Na...
£45.06
