StarTech.com 1 Port PCI Express 10/100 Ethernet Network Inter...
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card
£12.85
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 1x PCI design works in any PCI Express slot
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
This PCI Express based 10/100 Ethernet Card provides a simple way to connect a PCIe enabled server or workstation to a 10/100 Ethernet network and offers a broad range of features and functions, including support for both Full and Half Duplex operation as well as Wake On LAN (WOL) Power Management.
The PEX100S Ethernet Card includes both standard and low profile brackets and is compatible with most mATX (Slimline) and ATX system form factors, and features Auto MDI/MDIX automatic configuration, which helps to simplify installation and configuration.
Product Description StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card (PEX100S) - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
Ports 10/100 Ethernet
Dimensions (WxDxH) 2.1 cm x 12 cm
Weight 45 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
Processor 1 x Realtek Semiconductor RTL8101E
Compliant Standards IEEE 802.3x
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port PC...
£12.85
