This PCI Express IDE Controller Adapter Card provides a cost-effective way to use legacy drives with modern computers, by converting a PCI Express port into an IDE port.
Providing data burst transfer rates of up to 133MBps and support for PIO 0/1/2/3/4 and UDMA 33/66/100/133 operating modes, the IDE controller card offers an efficient way to add an IDE channel with support for two IDE drives on the same channel.
A complete dual profile solution, the PCI Express IDE controller card provides both standard and low profile brackets for adapting to slimline or small form factor system applications.
Product Description | StarTech.com 1 Port PCI Express IDE Controller Adapter Card - storage controller - ATA - PCIe x1 | Device Type | Storage controller - plug-in card | Bus Type | PCIe x1 | Interface | ATA | Data Transfer Rate | 133 MBps | Supported Devices | Hard drive | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits) | Manufacturer Warranty | Limited lifetime warranty |
General | |
Host Bus | PCIe x1 |
Storage Controller | |
Interface | ATA |
Expansion / Connectivity | |
Interfaces | 1 x ATA (internal) |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Cables Included | 1 x IDE cable - internal - 46 cm |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
