StarTech.com 1 Port PCI Express Low Profile Parallel Adapter...
StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP
£27.78
28 in stock
Delivery:
Standard: 1-3 working days
  • Type: Parallel adapter
  • Compatibility: PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
The PEX1PLP PCIe Parallel Adapter card can be installed in a PCI Express (PCIe) x1 slot, allowing you to connect EPP/ECP parallel peripherals to any computer, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability.
This high performance SPP/EPP/ECP parallel card adds 1 DB25 parallel port, perfect for connecting printers, scanners, CD-R/RW drives, memory card readers, bar code scanners and more. With the added convenience of plug-and-play capability, installing the parallel adapter card is hassle-free!
Product Description StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP Parallel Card (PEX1PLP) - parallel adapter
Device Type Parallel adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.0a
Ports IEEE 1284
Dimensions (WxDxH) 2.1 cm x 11 cm x 12 cm
Weight 65 g
Data Link Protocol Parallel
Data Transfer Rate 2.5 Mbps
System Requirements Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port PC...
£27.78
