StarTech.com 1 Port PCI Parallel Adapter Card
£24.28
12 in stock
Delivery:
Standard: 1-3 working days
Product codes
Add a high-speed parallel port (EPP/ECP) to your desktop computer through a PCI expansion slot. This high performance PCI based EPP/ECP parallel adapter card can be installed in a computer PCI slot to add one IEEE 1284 parallel port to your PC. A cost-effective way to connect parallel devices to the computer, with data transfer speeds of up to 1.5 Mbps (up to 3 times faster than on-board parallel ports).
The adapter card supports EPP, ECP, SPP and BPP parallel communications, and is simple to install in virtually any PC. The card supports Windows Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux, plus IRQ sharing and plug and play capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
A complete dual profile solution, the PCI parallel adapter card provides both standard bracket and low profile/half-height brackets for adapting to slimline or small form factor system applications.
StarTech.com 1 Port PCI Parallel Adapter Card - parallel adapter
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
IEEE 1284
Parallel
Data Transfer Rate
1.5 Mbps
Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / NT, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port PC...
£24.28
