StarTech.com 1 Port Professional USB to Serial Adapter Cable...
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention
£25.33
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: USB
  • Stock Status: In Stock
Product codes
The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
Product Description StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Ports RS-232
Dimensions (WxDxH) 3.5 cm 1.3 cm
Length 42 cm
Weight 33 g
Data Link Protocol RS-232
Data Transfer Rate 920 Kbps
Colour Black
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Pr...
£25.33
