StarTech.com 1 Port Professional USB to Serial Adapter Cable...
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention
£25.24
12 in stock
Delivery:
Standard: 1-3 working days
  • Type: Serial adapter
  • Compatibility: PC
  • Interface: USB
  • Stock Status: In Stock
Product codes
The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
Product Description StarTech.com USB to Serial Adapter - 1 Port - COM Port Retention - Texas Instruments TIUSB3410 - USB to RS232 Adapter Cable (ICUSB2321X) - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Ports RS-232
Dimensions (WxDxH) 3.5 cm 1.3 cm
Length 42 cm
Weight 33 g
Data Link Protocol RS-232
Data Transfer Rate 920 Kbps
Colour Black
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port Pr...
£25.24
