StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Serve...
StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - DIN Rail Mountable
£88.62
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A compact, cost-effective, serial-over-IP solution that includes a DIN rail mounting bracket
  • Redundant and flexible power input using the included power adapter, or 10~30V DC terminal block input
  • Safeguard your investment, with 15KV ESD (Electrostatic Discharge) protection
Product codes
A cost-effective way to connect, configure, and manage a remote RS-232 serial device over an IP network. This 1-Port Serial Device Server lets you remotely access and manage an RS232 serial device over a local or wide area network (LAN/WAN), for a simple and cost-effective serial-over-IP control solution.
For installation flexibility across a variety of environments, you can power the device server using the provided 12V DC power adapter, or using the integrated 10~30V DC terminal block.
To help ensure reliable performance and prevent possible damage, the serial device server offers 15KV ESD (Electrostatic Discharge) protection, so you can rest assured that the device server won't become damaged due to externally generated ESD.
This highly-customizable device server is easy to configure to suit your application. For easy setup, Windows users can use the provided Virtual COM port software, or the versatile web-based interface.
The RS232 device server supports Telnet (an operating system independent communication protocol), so it can be integrated into mixed OS environments (Windows, Mac, Linux).
Product Description StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - device server
Device Type Device server
Form Factor External
Data Link Protocol Ethernet, RS-232
OS Required Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
Power AC 100/230 V
Dimensions (WxDxH) 5.4 cm x 8.6 cm x 2.3 cm
Weight 65 g
Designed For P/N: IES101002SFP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port RS...
£88.62
