StarTech.com 1 Port RS232 Serial Adapter Card with 16950 UART...
StarTech.com 1 Port RS232 Serial Adapter Card with 16950 UART - 921.4Kbps
£38.13
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add RS232 DB9 capabilities without purchasing a new server or computer
  • PCI Express 1.1 compliant ensuring a reliable performance
  • Maximize case form factor integration with a low-profile or full-profile bracket
  • Wired / Wireless: Wired
  • Protocol: RS-232
  • Type: Serial adapter
  • Stock Status: In Stock
Product codes
This RS232 Serial Adapter Card lets you add an RS232 DB9 serial port to your computer through a PCI Express (PCIe) slot. It enables you to interact with serial devices such as card readers, printers, PIN pads, and modems, at speeds of up-to 921.4Kbps.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments. The card comes pre-configured with a low-profile bracket, and includes an optional full-profile bracket, so installation is easy regardless of the case form factor.
This PCIe to serial adapter supports the following features: Compatible with industry standard 16950 UART; Supports max baud rate of up-to 921.4Kbps; Provides 5/12V power output on Pin 9 when external power is connected; 128-byte depth FIFO per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits; Asix AX99100 chipset; PCI Express 1.1 compliant.
Product Description StarTech.com 1 Port RS232 Serial Adapter Card with 16950 UART - PCI Express Serial Port Card - 921.4Kbps - Windows & Linux Compatible (PEX1S953LP) - serial adapter
Device Type Serial adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
PCI Specification Revision PCIe 1.1
Ports RS-232 x 1
Dimensions (WxDxH) 4.62 cm x 9.8 cm x 1.8 cm
Weight 46.2 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Processor AX99100 - ASIX
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux 2.4 - 2.6.x
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port RS...
£38.13
