StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE...
StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet
£123.06
Delivery:
Standard: 1-3 working days
Key features
  • PoE support gives you the freedom to situate your serial device where it is needed even when no power outlet is available
  • IP-based connection to your serial devices allows remote administration from anywhere; even over the Internet
  • Remotely connect to multiple NETRS2321POE units with a single PC for simple and efficient management of devices from a single location
  • Type: PoE Kit
  • Stock Status: In Stock
Product codes
Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321POE 1 Port RS232 Serial Ethernet Device Server - PoE (Power Over Ethernet) allows you to install your RS232 devices anywhere on your TCP/IP Ethernet WAN/LAN, and access them as if they were right beside you - even over the Internet!
The Serial Device Server is designed to function seamlessly with your other integrated and add-on serial ports as if they were right inside your computer. Perfect for industrial automation, security, Point of Sale, or any long-range serial application, delivering reliable performance in any environment.
The Ethernet/serial device server supports PoE (Power over Ethernet) when connected to a PoE compliant device - eliminating the need for an external power supply and outlet, and making it easier to situate the device server as needed.
Product Description StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet - Serial over IP Device Server Adapter - PoE-Powered (NETRS2321POE) - device server
Device Type Device server
Form Factor External
Data Link Protocol Ethernet, Fast Ethernet, RS-232
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 6.6 cm x 10.7 cm x 2.5 cm
Weight 480 g
Designed For P/N: IES51000POE, IES61002POE, IES81000POE, IES8100POE, POEINJ1G, POEINJ1GW, POEINJ2GI, POEINJ4G, SVA12M5NA, UPOESPLT1G
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port RS...
£123.06
