StarTech.com 1 Port SATA to eSATA Slot Plate Bracket
£6.00
Delivery:
Product codes
StarTech.com's eSATA SATA adapter plate adds external data support to any existing Serial ATA controller. The adapter plate can be mounted to the rear panel of the computer case, providing straightforward eSATA to SATA connections allowing users to connect their eSATA device (hard drive enclosure, etc.) to the provided eSATA port which is an extension of the motherboard SATA data connector.
Designed to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections, the eSATA SATA adapter supports data transfer rates of up to 6 Gbps.
StarTech.com 1 Port SATA to eSATA Slot Plate Bracket - SATA internal to external panel - 30 cm
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
7 pin external Serial ATA - male
P/N: SAT5210U2EGB, SAT5210U2E, SAT2510U2E, SAT3550ESR, ECESATA22, SAT3510U2E, ESATCASE2
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port SA...
£6.00
