StarTech.com 1 Port USB 2.0 Extender Kit
£121.44
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Place your USB device exactly where you need it (up to 50 m), with this cost-effective USB-to-Ethernet extender
  • Metal housing for rugged durability
  • OS independent for fast, hassle-free setup
  • Type: USB Extender
  • Interface: USB 2.0
  • Ports: 1
  • Form Factor: External
  • Stock Status: In Stock
Product codes
Connect a USB 2.0 device to your computer over long distances, using this single-port USB extender. Here's a versatile and cost-effective USB 2.0 extender. It gives you the freedom you need to place your USB device further away, making it perfect for the homes, offices, classrooms, and many other environments. Now, you can easily access and use your USB 2.0 device in a remote location, up to 165 ft. (50 m) away, using Cat5 or Cat6 cable.
This USB extender overcomes the 16 ft. cable length limitations of traditional USB 2.0 cables, so you can create a more efficient, more flexible workspace.
It's an inexpensive USB-to-Ethernet solution that's ideal for virtually any USB 2.0 device. You can connect a webcam at the back of a classroom, or a printer in another room at the office, all up to 50 m away from your host computer.
Plus, with a power adapter included for the remote unit, you can connect power-hungry USB devices such as external hard drives.
Unlike other USB extenders that feature a plastic housing, this extender offers a metal casing that offers rugged durability. Whether the extender is installed in a permanent location, or will be moved from place to place, it gives you the peace of mind that your USB peripheral remains connected and accessible, right where you need it.
The USB 2.0-over-Cat5-or-Cat6 extender is OS independent, so it supports a variety of operating systems. Setup is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
Product Description StarTech.com 1-Port USB 2.0 Ethernet Extender Kit - Up to 165 ft. (50 m) Extension Over Cat5/Cat6 - USB Over IP/LAN Extender (USB2001EXTV) - USB extender - USB 2.0
Device Type USB extender
Form Factor External
Data Link Protocol USB 2.0
Max Transfer Distance 50 m
Designed For P/N: SVA5N3NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port US...
£121.44
