StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extende...
StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m)
£321.06
Delivery:
Standard: 1-3 working days
Key features
  • Extend a USB 2.0 device up to 100m/ 330ft away from the computer over a single Cat5 or Cat6 ethernet cable
  • Connect USB devices with up to 480Mbps of bandwidth and the full 500mA of power for improved speed, compatibility and reliability
  • Eliminates the need to cascade expensive, inflexible and space consuming USB hubs or repeaters for USB range extension
  • Type: Extender
  • Stock Status: In Stock
Product codes
Extend one USB 2.0 connection up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2001EXT2 USB over Cat5/Cat6 Extender lets you extend a USB 2.0 connection over distances of up to 100-meters (330-feet), over standard Cat5 or Cat6 Ethernet cabling.
Backward compatible with USB 1.x devices, the extender enables almost any kind of USB device to be placed at remote locations away from the host computer system.
With data bandwidth of up to 480 Mbps and no software installation required, the USB extender offers a fast, easy, and versatile solution for business or industrial applications with durable metal housing, an included surface-mounting bracket kit, and simple plug-and-play installation.
Plus, the extender provides up to the full 500 mA of power (with the use of an external power adapter at the remote end) allowing for greater compatibility with bus-powered USB devices.
Product Description StarTech.com 1-Port USB 2.0 Ethernet Extender - Up to 330ft(100m) Extension Over Cat5/Cat6 -Industrial USB Over UTP Repeater (USB2001EXT2) - USB extender - USB 2.0
Device Type USB extender
Form Factor External
Data Transfer Rate 480 Mbps
Data Link Protocol USB 2.0
Max Transfer Distance 100 m
Power AC 120/230 V
System Requirements Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits)
Designed For P/N: SVA5M4NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port US...
£321.06
