USB C Power Delivery Charger Compact Universally Compatible USB-IF Certified. This USB C Power Delivery charger provides next-generation technology that can fast charge your USB Type-C phone, tablet, or laptop that requires up to 60W.
Wide Compatibility
This USB-C wall charger is compatible with a vast array of USB Type-C devices such as the MacBook Pro 13-inch, XPS 13, Surface Book 2 and Lenovo ThinkPad X1 Carbon. A 3-foot (1 meter) USB-C to USB-C cable is included but the USB-C AC adapter is also compatible with other cable lengths.
While the USB Type-C power adapter is compatible with any USB-C Power Delivery device, it is recommended to use it with devices that require 60W or less for optimal charging performance.
Safe Charging
The USB-C portable charger comes with multiple forms of protection for your devices such as over-temperature protection, over-current protection, over-voltage protection and short-circuit protection.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
WCH1CUK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Product Description | StarTech.com USB C Wall Charger, USB C Laptop Charger 60W PD, 6ft/2m Cable, Universal Compact Type C Power Adapter, Dell XPS/Lenovo X1 Carbon, HP EliteBook, MacBook, USB IF/CE Certified - 60W PD3.0 Wall Charger (WCH1CUK) power adapter - USB-C - 60 Watt | Product Type | Power adapter | Dimensions (WxDxH) | 6.97 cm x 6.75 cm x 2.9 cm | Weight | 222.8 g | Colour | White | Localisation | United Kingdom | Output Connector Type | USB-C - on cable: USB-C | Voltage Required | AC 100-240 V | Voltage Provided | 5 / 9 / 12 / 15 / 20 V | Max Electric Current | 3 A | Power Provided | 60 Watt | Cables | USB-C cable - 1 m | Manufacturer Warranty | 2-year warranty |
General | |
Designed For | Tablet, mobile phone |
Width | 6.97 cm |
Depth | 6.75 cm |
Height | 2.9 cm |
Weight | 222.8 g |
Enclosure Colour | White |
Power Device | |
Input Connectors | Power BS 1363 |
Input Connectors Qty | 1 |
Output connectors | 24 pin USB-C |
Detachable Cable Connector Type | USB-C |
Features | Temperature protection, short circuit protection, over voltage protection, over-current protection |
Miscellaneous | |
Cables Included | USB-C cable - 1 m |
Compliant Standards | FCC, RoHS, USB-IF, REACH |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 13 cm |
Shipping Height | 3.5 cm |
Shipping Weight | 228 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
