StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender -...
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m)
£85.05
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provides more power at the remote end (up to 300mA), without external power, than most other similar USB Ethernet extenders, for more versatile device connection options
  • USB 1.1 extender supports any full-speed (12 Mbps) or low-speed (1.5 Mbps) USB peripheral at up to 131 feet (40 meters) - a cost-effective solution for extending USB devices that don't require the higher bandwidth offered by USB 2.0+
  • USB over Cat5/Cat6 eliminates the need to cascade expensive, inflexible and space consuming USB hubs or repeaters for extending the range of a USB device
  • Type: Extender
  • Stock Status: In Stock
Product codes
Extend a USB 1.1 device up to 40m (131ft) away from a computer, over a Cat5/Cat6 cable. The USB110EXT2 USB 1.1 Extender enables you to extend a USB 1.1 connection over distances of up to 40-meters (131-feet) using standard Cat5 or Cat6 UTP cabling, bypassing the normal limitation of 5m (15ft) for USB 1.1 devices and allows for the host computer system to be safely stored in a remote location.
The USB Extender features a compact design with no external power requirements, making it the ideal solution for remote USB cameras, keyboards, mice or other input devices for environments where install space or access to electrical outlets is limited.
Able to deliver up to 300mA of power (when supplied with 500mA from the host computer), the extender is fully compliant with the USB 1.1 specification, with support for up to 12Mbps of data bandwidth.
Product Description StarTech.com 1-Port USB 1.1 Extender - Up to 131 ft (40 m) over Cat5/Cat6 Extension - Up to 12 Mbps USB 1.1 Ethernet Extender (USB110EXT2) - USB extender - USB
Device Type USB extender
Form Factor External
Data Transfer Rate 12 Mbps
Data Link Protocol USB
Max Transfer Distance 40 m
System Requirements Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7
Dimensions (WxDxH) 2.5 cm x 8.5 cm x 4 cm
Weight 50 g
Designed For P/N: UUSBOTG
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port US...
£85.05
