StarTech.com 1 Port USB to RS232 DB9 Serial Adapter with Deta...
StarTech.com 1 Port USB to RS232 DB9 Serial Adapter with Detachable 6ft USB A to B Cable
£9.87
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Provides USB to straight-through RS232 serial connectivity
  • Detachable USB cable design
  • Supports baud rates up to 128 Kbps
  • USB-powered - no external power adapter required
  • Type: Serial adapter
  • Compatibility: Android, Mac, PC, Unix
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Add an RS232 serial port to your laptop or desktop computer through a detachable USB cable. The ICUSB232D 1 Port USB to Serial Adapter lets you add an RS232 DB9 serial port to your laptop or desktop computer through USB, so you can connect to, monitor and control a serial device. For easy connections, the adapter features a female USB type-B port, so you can choose the length of USB cable needed to reach your serial device (6ft / 1.8m USB A-B cable included).
The USB to RS232 adapter is a convenient and cost-saving solution for providing legacy serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment and a wide variety of other RS232 peripherals.
The USB to serial converter is easy to install and offers broad operating system compatibility including Windows, Mac OS and Linux for easy integration into mixed environments, and offers support for transfer rates up to 128 Kbps.
Product Description StarTech.com USB to Serial Adapter - Detachable 6 ft USB A-B Cable - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232D) - serial adapter - USB 2.0
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 3.2 cm x 5.9 cm x 2.2 cm
Colour Grey
System Requirements Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Android, Microsoft Windows Server 2012, Apple MacOS X 10.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits), Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port US...
£9.87
