StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB over IP Devi...
StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB over IP Device Server
£80.66
41 in stock
Delivery:
Standard: 1-3 working days
  • Type: Device Server
  • Interface: Ethernet, Fast Ethernet, Gigabit Ethernet, USB 2.0
  • Speed: [N/A]
  • Ports: 1
  • Form Factor: External
Product codes
Connect and share a high-speed USB 2.0 peripheral over a gigabit network. The USB1000IP 10/100/1000 Mbps Gigabit 1-Port USB over IP Device Server provides a simple and convenient way to extend and share a USB device over long distances, for multiple users connected to your Ethernet network. This flexible device auto-detects Ethernet network link speed and can connect through a network hub/switch/router, or directly to a PC, making it perfect for connecting and sharing devices such as mass storage, card readers, digital cameras, webcams, printers (including multi-function), fax, scanners or serial adapters with multiple users. Unlike slower 10/100 devices, gigabit speeds allow attached USB 2.0 devices to function at full speeds as if they were locally connected. The USB over IP Device server includes bundled software that provides a simple interface to view the status of, and connect to the detected device over the LAN, and features the option to automatically connect to your device after a reboot.
Product Description StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB over IP Device Server - device server
Device Type Device server
Form Factor External
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, USB 2.0
OS Required Microsoft Windows Vista / XP / 7, Windows 10 (32/64 bits)
Power AC 120/230 V
Dimensions (WxDxH) 3.8 cm x 7.7 cm x 2.3 cm
Weight 35 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10/100/10...
£80.66
