StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Conver...
StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km
£52.59
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Best value fiber media converter
  • Compact design makes it portable and unobtrusive to carry
  • Easily installed into any scenario with little to no configurations needed
  • Free Lifetime Technical Support
  • Lightweight design can be mounted anywhere
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Convert and extend a 10/100 Mbps Ethernet connection up to 2 km over Multi Mode SC fiber.
The MCM110SC2GB 10/100 Multi Mode Fiber Ethernet Media Converter SC 2 km creates an economical, cost-effective Ethernet-fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over an SC terminated multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2 kilometers (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using SC-terminated multimode fiber, while delivering solid network performance and scalability.
This versatile GbE Ethernet to Fiber converter is compatible with most 3COM, Cisco, Lucent and Nortel networks and fully complies with applicable IEEE 802.3 standards.
Product Description StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km - fibre media converter - 10Mb LAN, 100Mb LAN
Device Type Fibre media converter - RJ-45 / SC multi-mode
Form Factor External
Localisation United Kingdom
Cabling Type 10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate 100 Mbps
Optical Wave Length 1310 nm
Data Link Protocol 10Mb LAN, 100Mb LAN
Max Transfer Distance 2 km
Power AC 230V
Dimensions (WxDxH) 7.3 cm x 9.7 cm x 2.3 cm
Weight 90 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10/100 Et...
£52.59
