StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media...
StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km
£283.62
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Provides Ethernet to Fiber conversion as a standalone device, or can be installed into the ETCHS2U 20 slot chassis for added versatility
  • Rugged steel casing for durability in harsh environments
  • Wavelength Division Multiplexing (WDM) fiber cuts cabling costs in half, or doubles existing network speed/capacity using pre-existing cables
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Convert and extend a 10/100 Mbps Ethernet connection up to 12.4 miles/20 km over a single mode SC fiber cable. The ET90110WDM2 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC (20km) lets you extend a 10/100 Mbps Ethernet connection over single mode fiber, at distances up to 20 km (12.4 mi).
The converter offers Wavelength-Division Multiplexing (WDM), enabling bi-directional communication over a single strand of fiber, essentially doubling the capacity of your existing fiber infrastructure without having to install new cabling.
The Ethernet to WDM Fiber Kit includes both endpoints (two interchangeable modules) - a simple solution for connecting 10/100Base-T networks to remote locations using SC-terminated single mode fiber. The Ethernet to Fiber Converter also features a durable all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or one or both sides can be installed into a 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km (ET90110WDM2) - fibre media converter - 10Mb LAN, 100Mb LAN
Device Type Fibre media converter - RJ-45 / SC single-mode
Form Factor External
Localisation North America, United Kingdom, Europe
Cabling Type 10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate 100 Mbps
Optical Wave Length 1310 nm
Data Link Protocol 10Mb LAN, 100Mb LAN
Max Transfer Distance 20 km
Power AC 120/230 V
Dimensions (WxDxH) 9.5 cm x 16 cm x 2 cm
Weight 1.2 kg
Designed For P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10/100 Mb...
£283.62
