StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST...
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km
£94.99
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Link loss forwarding, remote status monitoring help ensure maximum up-time
  • Provides Ethernet to Fiber conversion as a standalone device, or can be installed into the ETCHS2U 20 slot chassis for added versatility
  • Rugged steel casing for durability in harsh environments
  • Type: Media Converter
Product codes
Convert and extend a 10/100 Mbps Ethernet connection up to 1.2 miles/2km over Multi Mode ST fiber. The ET90110ST2 10/100 Mbps Multimode Fiber Media Converter (ST, 2 km) lets you extend a Fast Ethernet network (10/100 Mbps) over multimode fiber, at distances of up to 2 km (1.2 miles).
A cost-effective solution for connecting a 10/100 Mbps Ethernet (10/100Base-T) network to remote network segments over a 100Base-FX fiber backbone. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to ST Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description StarTech.com 10/100 Mbps Ethernet to Fiber Optic Media Converter - Steel - Chassis Mount - ST Multimode - 1310nm - 2km (ET90110ST2) - fibre media converter - 10Mb LAN, 100Mb LAN
Device Type Fibre media converter - RJ-45 / ST multi-mode
Form Factor External
Cabling Type 10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate 100 Mbps
Optical Wave Length 1310 nm
Data Link Protocol 10Mb LAN, 100Mb LAN
Max Transfer Distance 2 km
Power AC 120/230 V
Dimensions (WxDxH) 9.5 cm x 16 cm x 2 cm
Weight 0.6 kg
Designed For P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£94.99
