StarTech.com 10/100 PoE Power over Ethernet Splitter 5V/12V
Product codes
The POESPLT100 10/100 Mbps PoE Power over Ethernet Splitter with 5-12V Output separates the data and power connections received from your Power Sourcing Equipment(PSE) such as a single port PoE injector or a PoE Switch.
At the remote end of your PoE connection, the POESPLT100 gives you a standard DC jack with selectable 5, 7.5, 9 or 12V output and separate Ethernet data connection allowing you to take advantage of power of Ethernet infrastructure, and use a variety of peripherals in places where no wall outlet exists.
StarTech.com 10/100 PoE Power over Ethernet Splitter 5V/12V - PoE splitter - 19.2 Watt
PoE splitter - external
240 g
Output Voltage
5 / 7.5 / 9 / 12 V
Power Capacity
19.2 Watt
Output connectors
1 x RJ-45
Silver
7.5 cm x 10.2 cm x 2.2 cm
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10/100 Po...
