StarTech.com 10 ft Cat5e Green Molded RJ45 UTP Cat 5e Patch C...
StarTech.com 10 ft Cat5e Green Molded RJ45 UTP Cat 5e Patch Cable
£3.88
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT10GN Cat5e Patch Cable (10 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com 10 ft Green Cat5e / Cat 5 Molded Patch Cable 10ft - patch cable - 3 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Wires per Cable
8 wires
Molded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Cat...
£3.88
