StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem...
StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M
£4.68
10 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Maintain reliable serial connections, free of EMI interference
  • Guaranteed dependability
  • Length: 3m
  • Stock Status: In Stock
Product codes
Connect your serial devices, and transfer your files. The SCNM925FM 10ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB25 male connector, allowing you to connect a 9-pin serial device to a 25-pin serial port, or transfer files from PC-to-PC via a serial connection.
Product Description StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M - Null modem cable - DB-9 (F) to DB-25 (M) - 10 ft - SCNM925FM - null modem cable - 3 m
Type Null modem cable
Length 3 m
Connector 9 pin D-Sub (DB-9) - female
Connector (Second End) 25 pin D-Sub (DB-25) - male
Designed For P/N: EC1S232U2, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S553LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S553, PEX4S553B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Cro...
£4.68
