StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F
£5.12
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
This 10 ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a serial printer to a 9-pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
Product Description StarTech.com 10' RS232 Serial Null Modem Cable - null modem cable - 3 m
Type Null modem cable
Length 3 m
Connector 9 pin D-Sub (DB-9) - female
Connector (Second End) 9 pin D-Sub (DB-9) - female
Designed For P/N: PEX1S553, PEX2S553LP, PEX2S553, PEX1S553LP, PCI2S232485I, PEX16S952LP, PCI8S950LP, PEX1S552LP, PEX2S552LP, PEX4S952LP, ECS0016GB, ECS0016, PEX2S552, PEX1S552, PEX8S950LP, PEX4S950, PEX4S550, NETRS2321E, EC4S950, CB1S485, CB2S950, PEX2S950, CB1PECP, EC2S950, EC1S950, CB4S950, PCI2S950DV
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DB9...
£5.12
