StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F
£5.14
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 3m
  • Type: Serial
  • Stock Status: In Stock
Product codes
This 10 ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a serial printer to a 9-pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
Product Description StarTech.com 10' RS232 Serial Null Modem Cable - Null modem cable - DB-9 (F) to DB-9 (F) - 10 ft - SCNM9FF - null modem cable - DB-9 to DB-9 - 3 m
Type Null modem cable
Length 3 m
Connector 9 pin D-Sub (DB-9) - female
Connector (Second End) 9 pin D-Sub (DB-9) - female
Designed For P/N: EC1S232U2, EC1S952, EC2S952, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI2S232485I, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S232485, PEX4S553, PEX4S553B
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DB9...
£5.14
