Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM10 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 10ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM10 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description | StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M - DisplayPort cable - 3 m | Type | DisplayPort cable | Length | 3 m | Connector | DisplayPort - male | Connector (Second End) | DVI-D - male | Compliant Standards | FCC, RoHS | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Plated Connector | Nickel |
Length | 3 m |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
