StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable...
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
£24.94
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect a DisplayPort source directly to a VGA display or projector, with no additonal adapters or cables
  • Save upgrade costs by connecting your DisplayPort computer to a VGA monitor or Projector
  • Flexible monitor placement, with 10ft of cable length
  • Length: 3.05m
  • Stock Status: In Stock
Product codes
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 10ft long cable. The DP2VGAMM10B 10ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new Mini DisplayPort computer to work with an older VGA monitor or projector.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
Product Description StarTech.com 10ft DisplayPort to VGA Adapter Cable DP to VGA - Black - DisplayPort cable - 3.05 m
Type DisplayPort cable
Features Latched
Length 3.05 m
Connector DisplayPort - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards FCC, RoHS
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft Dis...
£24.94
