StarTech.com 10 ft DVI-D Dual Link Cable - M/M
£12.72
12 in stock
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 3m
  • Stock Status: In Stock
Product codes
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM10 10ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 10 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
Product Description StarTech.com 10 ft DVI-D Dual Link Cable - M/M - DVI cable - 3 m
Type DVI cable - dual link
Length 3 m
Connector DVI-D - male
Connector (Second End) DVI-D - male
Colour Black
Designed For P/N: RKCONS2001GB, USB2DVIPRO, RACKCONS2001, DP2DVID, SV431DVIDGB, DVI2HDMI, USB2DVIE, HDMI2DVI, SV431DVIDDU, SV431DDUSB, SV231DDUSB, USB2DVI, VID2DVIDTVGB, VGA2DVIIGB, VGA2DVII, VID2DVIDTV, SV421DVIDD, SV221DVIDD, SV221DVI
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DVI...
£12.72
