StarTech.com 10 ft DVI-D Single Link Cable - M/M
£9.57
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Molded connectors with strain relief maintain a durable connection, helping to prevent damage to the connectors, for long term, error-free DVI to DVI video performance
  • Guaranteed reliability
  • Type: DVI
  • Length: 3m
  • Stock Status: In Stock
Product codes
Provides a high speed, crystal clear connection between your DVI digital devices. The DVIDSMM10 10ft DVI-D Single-Link Cable provides a highly reliable, purely digital connection between and is perfect for hooking up a desktop workstation to a DVI monitor, or to plug a laptop into a projector for presentations.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable monitor cable is designed to provide a high quality digital video experience.
Product Description StarTech.com DVI Cable - 10 ft - Single Link - Male to Male Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord - DVI to DVI Cable (DVIDSMM10) - DVI cable - 3 m
Type DVI cable - single link
Length 3 m
Connector DVI-D - male
Connector (Second End) DVI-D - male
Compliant Standards Plug and Play
Colour Black
Designed For P/N: BOX4CABLE, CDP2DVIW, CDPVGDVHDBP, DKT30CDVPD, DP2DVIADAP, DVI2HDMIA, DVI2VGACON, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, PEXHDCAP2, PEXHDCAP60L2, ST122DVIA, ST124DVIA, SV431DD2DU3A, SV565FXDUSA, SV565UTPDUV, USB32DVCAPRO, USB3HDCAP, USB3SDOCKD, USB3SDOCKHD, USBC2DVCAPRO, VHDCI24DVI, VSEDIDDVI
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 10 ft DVI...
£9.57
